*setbackgroundgradient
Sets the gradient background color1 and color2 values.
*setbackgroundgradient type
HyperMesh Tcl Modify Command
Sets the gradient background type.
type
The type of gradient to use. Valid values are:
  • 121
  • diagonal1
  • diagonal2
  • vertical
To set the gradient background to 121:
*setbackgroundgradient 121
   # Handle error
