*shelloffset
Offsets shells along their element normal direction.
*shelloffset mark_id corner_type distance_type distance offset_type
HyperMesh Tcl Modify Command
- mark_id
 - The ID of the mark containing the shell elements to be offset. Valid values are 1 and 2.
 - corner_type
 - 0 - Offset the elements using square corners.
 - distance_type
 - 0 - Offset elements using distance parameter.
 - distance
 - The distance to move the elements. Only valid when distance_type=0.
 - offset_type
 - 0 - Offset the elements in the positive normal direction.
To offset the displayed shell elements along their positive normal by a value of 0.2, using square corners:
*createmark elements 1 displayed
*shelloffset 1 0 0 0.2 0
      To offset the displayed shell elements along their positive normal by a value of 0.2, using CFD corners, with surfaces 1 and 2 as along geometry:
*createmark surfaces 2 1 2
*shelloffset 1 8 0 0.2 0
   # Handle error
