*createlistbypathpanel
Provides a panel to create an ordered list of entities for use in a subsequent command, with the collector set to "by path".
*createlistbypathpanel entity_type list_id message
HyperMesh Tcl Modify Command
entity_type
Entity type to put on the list. Valid values are:
  • elems
  • laminates
  • lines
  • nodes
  • plies
  • surfs
list_id
The ID of the list to populate. Valid values are 1 and 2.
message
A string indicating a message to display in the status bar.
Examples
To create a line from a user specified list of nodes:
*createlistbypathpanel nodes 1 "Select nodes for the line:"
set node_list [ hm_getlist nodes 1 ];
if { ! [ Null node_list ] } {
    *linecreatefromnodes 1 0 150 5 179
   # Handle error
Version History
11.0.130
