*nodeplaceatxyz
Moves a node to a location on a surface and associates the node to the surface.
*nodeplaceatxyz node surface location
HyperMesh Tcl Modify Command
- node
 - The ID of the node.
 - surface
 - The ID of the surface to which the node should be associated.
 - location
 - The location of the point on the surface where the node is to be moved.
To move node 115 to surface 1 at location (75,30,86):
*nodeplaceatxyz(115,1,75,30,86)
None.
