*createlistpanel
Provides a panel to create an ordered list of entities for use in a subsequent command.
*createlistpanel entity_type list_id message
HyperMesh Tcl Modify Command
- entity_type
 - The type of entities to put on the list. Valid values are:
- elems
 - laminates
 - lines
 - nodes
 - plies
 - surfs
 - list_id
 - The ID of the list to populate. Valid values are 1 and 2.
 - message
 - A string indicating a message to display in the message bar.
Examples
*createlistpanel nodes 1 "Select nodes for the line:"
set node_list [ hm_getlist nodes 1 ];
if { ! [ Null node_list ] } {
    *linecreatefromnodes 1 0 150 5 179
}Errors
   # Handle error
