*morphalteranglevec
Alters the angle for three nodes using morphing and measuring perpendicular to a vector.
*morphalteranglevec h1type h1mark h2type h2mark n1 n2 n3 hold ang sym con vec
HyperMesh Tcl Modify Command
- h1type
 - Handles
 - h1mark
 - Handle mark number - end a
 - h2type
 - Handles
 - h2mark
 - Handle mark number - end b
 - n1
 - ID of node - end a
 - n2
 - ID of node - vertex
 - n3
 - ID of node - end b
 - hold
 - Determines which of the three nodes should be held:
 - ang
 - New angle between n1 and n3 with n2 as the vertex
 - sym
 - Flag to determine whether or not to use symmetry: d
 - con
 - Flag to determine whether or not to use constraints:
 - vec
 - Vector mark number
*morphalteranglevec (HANDLES,0,HANDLES,1,132,783,171,0,45.0,1,1,1)
      The handles on the marks will be moved based on hold through an angle based on the current angle and ang, measured perpendicular to vector vec, and using n1, n2, and n3 to determine the perturbations. If symmetry is used all handles linked to marked handles by symmetry will also be perturbed. If constraints are used they will be applied to the perturbations.
None.
