*attributeupdateentityidarrayelementmark
Updates one element of an attribute of type 2D entity ID array.
*attributeupdateentityidarrayelementmark entity type mark identifier solver status behavior target entity index value
HyperMesh Tcl Modify Command
- entity type
 - The type of entity that owns the attribute.
 - mark
 - The number of the mark where the list of IDs resides.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - target entity
 - The type of entity to which the attribute refers.
 - index
 - Index into the array (first index is zero).
 - value
 - The new value of the 2D array element.
Examples
Assuming you want to update an element in an entity ID array attribute to point to a loadcol with an ID of 5. The attributes are found on materials with ID's of 7 and 8, do the following:
*createmark(materials, 1) 7 8
*attributeupdateentityidarrayelementmark(materials, 1, 1234, 1, 2, 0, loadcols, 0, 5)
