*CE_GlobalSetDouble
Set global double parameters relating to the display of connectors.
*CE_GlobalSetDouble name value
HyperMesh Tcl Modify Command
This command sets global double parameters to control the display of connectors.
- name
 - The name of the parameter to set:
- g_ce_size
 - Determines the display size of connectors.
 - value
 - The double value to set for the name parameter.
Examples
*CE_GlobalSetDouble g_ce_size 2.0Version History
9.0
