*CE_ConnectorCreateWithRules
Creates connector(s) at the specified location(s) with defined rules.
*CE_ConnectorCreateWithRules entities markmask entity entitymark ent_state ce_rules ce_le_rule tol_flag tolerance num_ents
HyperMesh Tcl Modify Command
- entities
 - Types that specify location of connector(s).
- Nodes
 - Points
 - markmask
 - The mark for nodes or points.
 - entity
 - The entity type to be added to the connector as a link:
- nodes
 - elems
 - tags
 - surfs
 - comps
 - entitymark
 - Mark of entities to add to the connector as links.
 - ent_state
 - Specifies whether geometry or FE gets precedence during realization of connector.
            Applicable to components and surfaces only.
- 0 - geoms
 - 1 - elems
 - ce_rules
 - Rule to specify if and how a link entity is to be added to a connector.
- 0 - none
 - 1 - now
 - 2 - at fe realize
 - ce_le_rule
 - Rule that specifies how an entity is to be remembered by the connector.
- 0 - none
 - 1 - use ID
 - 2 - use name
 - tol_flag
 - Specifies if tolerance value is applicable.
- 0 - Use default.
 - 1 - Use specified value.
 - tolerance
 - Specified to add entities only with in the given tolerance from the specified connector (same as search radius in fe realize panel).
 - num_ents
 - Total number of entities to add/update connector (connectors thickness (2T, 3T, etc.) value).
Examples
*createmark(points, 1) 1
*createmark(components, 2) 21 23 24 27
*CE_ConnectorCreateWithRules(points, 1, components, 2, 1, 1, 1, 1, 1.0, 2)Created connector is displayed as a cylinder and only the closest two components are added to it. The total number of layers defined at the connector is 2.
