*morphconstraintupdatearcrad
Updates a model type constraint based on the radius or arc length of an edge domain.
*morphconstraintupdatearcrad stype smark atype amark type mcon plane dptr radius bound arc color
HyperMesh Tcl Modify Command
- stype
 - SHAPES
 - smark
 - Mark number of shapes
 - atype
 - NODES or LINES
 - amark
 - Mark number of node or line used for radius measurement
 - type
 - 0 - Measure radius or arc angle using domain
 - mcon
 - ID of morph constraint
 - plane
 - mark number of plane for axis
 - dptr
 - ID of edge domain
 - radius
 - Constrained radius or arc angle
 - bound
 - -1 - Greater than specified angle
 - arc
 - 0 - Radius
 - color
 - The color of the constraint. Valid values are 1 through 64.
This command updates a model type constraint for the selected domain with the option of updating the radius or arc angle to be measured in the plane of the domain, about an axis, about a line or about a node, and the option of having the radius or arc angle forced to be greater than, less than, or equal to the specified value.
If arc is 0, the radius will be constrained. If arc is 1, the arc angle will be constrained.
The shapes on the mark will be used to force the model into compliance with the specified constraint if possible.
*morphconstraintupdatearcrad (SHAPES,1,NODES,1,0,5,1,21,5.0,0,0,32)
None.
