*findattachedelementfaces
Returns information to a table about solid elements attached to quad/tria element.
*findattachedelementfaces mark_id table_id
HyperMesh Tcl Modify Command
- Input element IDs
 - Attached element IDs
 - Attached element face IDs
 - Attached element configs
 - Input element collector IDs
 - Input element normal reversed flags
- mark_id
 - The mark ID containing the input quad/tria elements. Valid values are 1 and 2.
 - table_id
 - The table ID to output the results to. The table must have 6 integer columns.
*createstringarray 6 int int int int int int
*tablecreate "attachedelementtable" 1 1 1 6
set table_id  [hm_getvalue tables name=attachedelementtable dataname=id]
*createmark elems 1 "by config" 104 103
*findattachedelementfaces 1 $table_id
array unset faceTable
set numOfRows [hm_getvalue tables id=$table_id dataname=rows]
for {set r 0} {$r < $numOfRows} {incr r} {
    lappend faceTable(shlList)   [hm_getvalue tables id=$table_id dataname=cellvalue COLUMN=0 ROW=$r]
    lappend faceTable(solList)   [hm_getvalue tables id=$table_id dataname=cellvalue COLUMN=1 ROW=$r]
    lappend faceTable(solFaceId) [hm_getvalue tables id=$table_id dataname=cellvalue COLUMN=2 ROW=$r]
    lappend faceTable(solCfg)    [hm_getvalue tables id=$table_id dataname=cellvalue COLUMN=3 ROW=$r]
    lappend faceTable(shlCmp)    [hm_getvalue tables id=$table_id dataname=cellvalue COLUMN=4 ROW=$r]
    lappend faceTable(shlRevNrm) [hm_getvalue tables id=$table_id dataname=cellvalue COLUMN=5 ROW=$r]
   # Handle error
}Version History
11.0.101
