*CE_ConnectorLineCreateWithRules
Creates connector(s) at the specified location(s) with defined rules.
*CE_ConnectorLineCreateWithRules entities markmask density spacing half_spacing_offset offset entity entitymark ent_state ce_rules ce_le_rule tol_flag tolerance num_ents
HyperMesh Tcl Modify Command
- entities
 - Types that specify location of connectors.
 - markmask
 - The mark for lines.
 - density
 - Integer number to split line into number of points. Spacing between points (= line_length/density).
 - spacing
 - Float number to split line into number of points with specified distance between points (= spacing).
 - half_spacing_offset
 - Create points from an offset (= spacing/2) from the start and end of line.
 - offset
 - Create points from an offset (= offset) from the start and end of line.
 - entity
 - Type of entity to be added to the connector as a link.
- nodes
 - elems
 - tags
 - surfs
 - comps
 - entitymark
 - Mark of entities to add to the connector as links.
 - ent_state
 - Specifies whether geometry or FE has precedence during realization of connector.
            Applicable to components and surfaces only.
- 0 - geoms
 - 1 - elems
 - ce_rules
 - Rule to specify if and how a link entity is to be added to a connector.
- 0 - none
 - 1 - now
 - 2 - at fe realize
 - ce_le_rule
 - Rule that specifies how an entity is to be remembered by the connector.
- 0 - None
 - 1 - Use ID
 - 2 - Use name
 - tol_flag
 - Specifies if tolerance value is applicable.
- 0 - Use default.
 - 1 - Use specified value.
 - tolerance
 - Specified to add entities only with in the given tolerance from the specified connector (same as search radius in fe realize panel).
 - num_ents
 - Number of entities to add/update for a connector (connectors thickness (2T, 3T, etc.) value).
Examples
*createmark(lines, 1) 1
*createmark(components, 2) 21 23 24 27
*CE_ConnectorLineCreateWithRules(points, 1, 0, 2.0, 1, 0.0, components, 2, 1, 1, 1, 1, 1.0, 2)A created connector is displayed as a cylinder at the center of the line and only the closest two components are added to it. The total number of layers defined at the connector is two.
