*jpegfilenamed
Captures the graphics area to a JPEG image with the specified name.
*jpegfilenamed filename
HyperMesh Tcl Modify Command
The color and background settings can be specified using the *graphicsfilecolor and *graphicscolorblankbackground commands.
filename
The full path and file name of the image.
To capture the graphics area to a JPEG image named "C:/my_images/model.jpg":
*jpegfilenamed "C:/my_images/model.jpg"
   # Handle error
