*barrierpositioner
Positions the barrier according to various protocols with respect to a given vehicle.
*barrierpositioner vehiclemark=<value> barriermark=<value> vehiclefrontaxis=<value> barrierfronaxis=<value> basenode=<value> inclinationnode=<value> ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Positions the barrier according to various protocols with respect to given vehicle.
The model must contain vehicle and barrier parts, the vertical axis of these parts must be aligned with global positive z axis (0,0,1), the barrier model must be imported as an include file, and all barrier parts must be in the same include file.
- barrierfrontaxis={<x y z>}
 - The vector pointing toward the front of the barrier. It must be different from the global z axis. This is mandatory.
 - basenode={<x y z>}
 - The coordinates of the base node for ground. This is mandatory.
 - barrierfoamdistance=<value>
 - The frontal distance of the foam part of the barrier to be considered for calculating the bounding box of those nodes/coordinates for offset or overlap, default is 350.0.
 - barrierheightposition=<value>
 - The desired final distance between vehicle and barrier, defaults are given for each config below.
 - barrierimpactside=<value>
 - The default is 1 except for config=16. Valid values are:
 - barrierlateralangle=<value>
 - The lateral angle with which the barrier is rotated from expected barrier final axis. For front load case, barrier final axis is opposite of vehicle front axis. For side load case, it is lateral axis of vehicle and towards the vehicle, whereas it is front axis of vehicle for rear load case. Defaults are 0.0 except for config=14 the default is 15 degrees and for config=18 the default is 75 degrees.
 - barriermark=<value>
 - The ID of the mark of barrier components. Valid values are 1 and 2. This is mandatory.
 - barrieroverlappercent=<value>
 - The percentage overlap between car and vehicle for front load cases, defaults are given for each config below.
 - barriervehicleoffsetdist=<value>
 - The desired final distance between vehicle and barrier, default is 10.0.
 - config=<value>
 - The type of load case and regulation.  Valid values are:
Config Load Case Regulation Description barrierheightposition barrieroverlappercent rpointoffset 11 Side IIHS Mobile Deformable Barrier (MDB) 379.0 - - 12 Side FMVSS-214D Passenger Car 279.0 - - 13 Side FMVSS-214D MPV 279.0 - - 14 Side Euro NCAP MDB 300.0 - 250.0 15 Side UN-R95 MDB 300.0 - 0.0 16 Side J-NCAP MDB 300.0 - 250.0 17 Side C-NCAP MDB 350.0 - 250.0 18 Side Euro NCAP Oblique Pole 102.0 - - 31 Front Euro NCAP ODB 200.0 40.0 - 32 Front Euro NCAP MPDB 150.0 50.0 - 33 Front IIHS Small Overlap Rigid Barrier 0.0 25.0 - 34 Front US NCAP OMDB 200.0 15.0 - 51 Rear FMVSS-301 229.0 70.0 -  - inclinationnode={<x y z>}
 - The coordinates of the inclination node for ground. This is mandatory.
 - rpointoffset=<value>
 - The barrier distance from R Point of vehicle for side load cases or impact reference distance (IRD).
 - sidenode={<x y z>}
 - The coordinates of the side node for side load cases.
 - vehiclefrontaxis={<x y z>}
 - The vector pointing toward the front of the vehicle. It must be different from the global z axis. This is mandatory.
 - vehiclemark=<value>
 - The ID of the mark of vehicle components. Valid values are 1 and 2. This is mandatory.
 - wheelbasedistance=<value>
 - The wheelbase distance as the distance between front wheel axis and rear wheel axis, used for IRD calculations.
Examples
*createmark comps 1 "by include" $includeidvehicle
*createmark comps 2 "by include" $includeidbarrier
*barrierpositioner config=31 vehiclemark=1 barriermark=2 vehiclefrontaxis={1 0 0} barrierfrontaxis={-1 0 0} basenode={0.000087 913.163 0} inclinationnode={-4806.71 913.163 0} barrieroverlappercent=40.0 barrierheightposition=200.0 barrierfoamdistance=150.0 barriervehicleoffsetdist=10.0*createmark comps 1 "by include" $includeidvehicle
*barrierpositioner config=34 vehiclemark=1 barriermark=2 vehiclefrontaxis={1 0 0} barrierfrontaxis={1 0 0} basenode={0.000087 913.163 0} inclinationnode={-4806.71 913.163 0} barrieroverlappercent=35.0 barrierheightposition=200.0 barrierlateralangle=15.0 barriervehicleoffsetdist=10.0 barrierfoamdistance=150.0*createmark comps 1 "by include" $includeidvehicle
*barrierpositioner config=11 vehiclemark=1 barriermark=2 vehiclefrontaxis={1 0 0} barrierfrontaxis={0 1 0} basenode={0.000087 913.163 0} inclinationnode={-4806.71 913.163 0} sidenode={-777.060791 982.340820 330.154846} wheelbasedistance=2538.0 barrierimpactside=1 barrierheightposition=379.0 barrierfoamdistance=350.0 barriervehicleoffsetdist=10.0Errors
   # Handle error
}Version History
2021
