*springthreenoded
Creates a spring element between three nodes using an orientation vector.
*springthreenoded node_id1 node_id2 node_id3 dof property_name vector_id
HyperMesh Tcl Modify Command
Creates a spring element between three nodes using an orientation vector. It will have config 24 and type 1 connecting node1 to node2, and node 2 to node 3. This is supported for Radioss only.
- node_id1
 - The ID of the first node.
 - node_id2
 - The ID of the second node.
 - node_id3
 - The ID of the third node.
 - dof
 - The degree of freedom for the element.
 - property_name
 - The name of the property to assign to the element.
 - vector_id
 - The ID of the orientation vector assigned to the element.
To create a three noded spring element between nodes 100, 101 and 102 with DOF 2, property springprop and orientation vector ID 51:
*springthreenoded 100 101 102 2 springprop 51
   # Handle error
}Version History
14.0.130
