*allsuppressoutput
Sets the export/do not export state of all entities.
*allsuppressoutput state
HyperMesh Tcl Modify Command
state
0 - Set the state to 'export'.
1 - Set the state to 'do not export'.
Examples
To set all entities to 'export':
*allsuppressoutput 0
   # Handle error
Version History
9.0
