*AE_UpdateLink
Updates the link for selected attachment entities.
*AE_UpdateLink mark_id uid ?pid?
HyperMesh Tcl Modify Command
Updates the link for selected attachments using a new part.
mark_id
The ID of the mark containing the attachments. Valid values are 1 and 2.
uid
The unique ID of the new part.
pid
The ID of the new part. Required when the part is an instance.
Examples
To update the link of attachments 101, 102, 103 using a part with UID "frame_1":
*createmark attachments 1 101 102 103
        *AE_UpdateLink 1 "frame_1"
   # Handle error
Version History
2021.2
