*meshline_mask_class_element
Masks underlying meshline class elements.
*meshline_mask_class_element flag reserved
HyperMesh Tcl Modify Command
This command masks underlying meshline class elements.
flag
0 - Turn off the underlying meshline class elements.
1 - Turn on the underlying meshline class elements.
reserved
Reserved for future use. Must be set to 0.
To turn off the underlying meshline class elements:
*meshline_mask_class_element 0 0
   # Handle error
Version History
11.0
