*CE_FE_3DQuality
Checks the quality of 3D elements (welds) created by realizing connector entity (CE).
*CE_FE_3DQuality ce_inmark entities outputmark length_flag length jacobian_flag jacobian
HyperMesh Tcl Modify Command
Checks the quality of 3D elements (welds) created by realizing connector entity (CE). It places all failed connectors on an output mark and highlights them.
- ce_inmark
 - Mark of displayed connectors.
 - entities
 - Only quality checks for Elements are now supported.
 - outputmark
 - All connectors that contain FE (welds) that failed quality check criteria are placed on this mark. Mark only connectors.
 - length_flag
 - Check if the length of FE (welds) exceeds a certain value specified by the length parameter.
 - length
 - The value of the length of the weld that should not be exceeded. Used in conjunction with length_flag.
 - jacobian_flag
 - Check if the Jacobian of the FE (3D welds) exceeds the value specified by the jacobian parameter.
 - jacobian
 - The value of the Jacobian of the 3D weld that should not be exceeded. Used in conjunction with jacobian_flag.
Examples
*createmark(connectors,1) 1 2 3
*CE_FE_3DQuality(1,elements,2,1,3.0,1,0.7)
