Extract the final design geometry from OptiStruct topology,
    topography and shape optimization results, and achieve smoothed plies from free-size
    optimization results on composites.
      *ossmooth_12
        modelsel exemode load_op outputcode filepath_fem filepath_sh filepath_grid
          isosurface autobead string_array number_of_strings
      HyperMesh Tcl Modify Command
          - modelsel
          - Model selection option.
          - 0 - Specify model file path to read.
          - 1 - Use current model in HyperMesh.
          - exemode
          - Flag indicating the execution mode of OSSmooth. Valid values are:
              - 0 - Extract geometry only
              - 1 - Extract geometry and inherit boundary conditions for FEA reanalysis
              - 2 - Smoothing plies from free-sizing optimization results on composites
          - load_op
          - Execution/load option. Valid values are:
              - 0 - Create .oss file only to be used in standalone version
                (do not execute ossmooth)
              - 1 - Do not load geom into HyperMesh.
              - 2 - Load geom intoHyperMesh.
          - outputcode
          - Output file format. Valid values are:
              - 1 - Nastran
              - 2 - IGES
              - 3 - STL
              - 4 - H3D
              - 5 - STEP
              - 6 - PARASOLID
              - 7 - IGES (advanced)
          - filepath_fem
          - The full name and path to the OptiStruct
            .fem results file generated from the optimization.
          - filepath_sh
            .sh results file generated from the optimization.
          - filepath_grid
            .grid results file generated from the optimization.
          - isosurface
          - Flag indicating whether to create an isosurface.
          - autobead
          - Flag indicating whether to create an autobead design.
          - string_array
          - The ID of the string array that contains the additional parameters. The string array
            is created using the *createstringarray command. This should always
            be set to 1.
          - number_of_strings
          - Integer indicating the size (number of strings) in the string array created using
              *createstringarray. The valid strings are documented below.
          - Each argument can be either space or comma separated. There will be at most five
            strings of parameters, depending on the operations selected. Each string is introduced
            as
            follows:
"isosurf: surfacecode surfacemode densitythreshold detectbridge lowthreshold distancecoefficient optismoothboundary lapiteration lapfeatureangle lapsmoothboundary drawrecovery"
          - This sting is only required when isosurface = 1.
                - surfacecode
                - The method used for isosurface extraction. Valid values are:
                    - 0 - No smoothing, isosurface only
                    - 1 - Optimization based smoothing
                    - 2 - No smoothing, element threshold
                    - 3 - Laplacian smoothing
                - surfacemode
                - Isosurface mode indicating how to process non-design
                  elements. Valid values are:
                    - 0 - Keep all non-design elements with half layer around
                    - 1 - Split only intersected non-design elements
                    - 2 - Split overlap non-design elements with half layer around
                    - 3 - Split overlap non-design elements
                    - 4 - Extract shells with half layer around non-design
                    - 5 - Extract shells without half layer around non-design
                - densitythreshold
                - Threshold value for topology optimization (real value ≥ 0 and ≤ 1).
                - detectbridge
                - Flag indicating whether to detect connectivity in isosurface (1=yes, 0=no).
                - lowthreshold
                - The low density threshold for connectivity detection (real value ≥ 0 and ≤ 1).
                  Low threshold value must be smaller than density threshold value.
                - distancecoefficient
                - The distance coefficient to use in optimization based smoothing (real value ≥
                  -50 and ≤ 50).
                - optismoothboundary
                - Flag indicating whether to include the boundary or not in optimization based
                  smoothing (1=yes, 0=no).
                - lapiteration
                - The number of iterations to use in Laplacian smoothing (integer ≥ 0).
                - lapfeatureangle
                - The feature angle to use in Laplacian smoothing (real value ≥ 1 and ≤ 80).
                - lapsmoothboundary
                - Flag indicating whether to include the boundary or not in Laplacian smoothing
                  (1=yes, 0=no).
                - drawrecovery
                - Flag indicating whether to recovery draw constraints in topology optimization
                  (1=yes,
                  0=no).
"autobead: shapeopt beadthreshold autobeadlayer"
                - This string is only required when autobead > 0.
                - shapeopt
                - Method used for topography or shape optimization interpretation. Valid values are:
                    - 1 - Create autobead
                    - 2 - Update new coordinates to original mesh
                - beadthreshold
                - Threshold value for autobead (real value ≥ 0 and ≤ 1).
                - autobeadlayer
                - Layer value for autobead (integer value 1 or
                  2).
"remesh: remeshsize meshtype attachtype remeshlayer remeshfeatureangle"
                - This string is only required when using remeshing.
                - remeshsize
                - The element size used in remeshing.
                - meshtype
                - Flag indicating the elements generated in remeshing. Valid values are:
                    - 0 - trias
                    - 1 - quads
                    - 2 - mixed
                    - 3 - right trias
                - attachtype
                - Flag indicating which elements will be remeshed. Valid values are:
                    - 0 - Remeshing a numer of layers elements around PLOT elements
                    - 1 - Remeshing all elements
                - remeshlayer
                - The number of layers when attachtype = 0 (integer ≥ 0).
                - remeshfeatureangle
                - The feature angle used in
                  remeshing.
"other_params: units tetrameshingcode createplot surfacereduction reductionfeatureangle"
                - This string is required when isosurface = 1 or
                    autobead = 1.
                - units
                - Units used for IGES and STEP output. Valid values are:
                    - 1 - inch
                    - 2 - mm
                    - 4 - foot
                    - 6 - meter
                    - 10 - cm
                - tetrameshingcode
                - Flag indicating whether to create tetramesh after creating isosurface (1=yes,
                  0=no).
                - createplot
                - Flag indicating whether to create PLOT elements (1=yes, 0=no).
                - surfacereduction
                - Flag indicating whether to use surface reduction (1=yes, 0=no).
                - reductionfeatureangle
                - The feature angle to used for surface reduction (real value ≥ 1 and ≤
                  80).
"ply: plyfile plysmoothiteration smallregiontype smallregion splitdisconnected"
                - This string is required when exemode = 2.
                - plyfile
                - The full name and path to the .fem file to save the
                  smoothed result plies.
                - plysmoothiteration
                - The number of iterations to use in ply shape smoothing (integer ≥ 0).
                - smallregiontype
                - Flag indicating method used for small region (element patch or hole) detection.
                  Valid values are:
                    - 0 - Detect small regions by area ratio
                    - 1 - Detect small regions by element count
                - smallregion
                - Threshold value to use for small region elimination. Small region depends on
                    smallregiontype: when smallregiontype = 0,
                  this indicates the area ratio (real value ≥ 0 and < 1, calculated by small
                  region area/total design area). When smallregiontype = 1, this
                  indicates the element count (integer, ≥0).
                - splitdisconnected
                - Flag indicating whether to split disconnected patches into new plies (1=yes,
                  0=no).
    Examples
      To execute OSSmooth FEA reanalysis on the current model in HyperMesh (the C:/test/os1.fem and
          c:/test/os1.sh files), create isosurface with 0.3 density threshold,
        split all quads on non-design/design interface, Laplacian smoothing, with 10 iterations and
        30 degrees feature angle, do remeshing on 2 layers of elements around PLOT, with element
        size 0.5, and feature angle 30:
      *createstringarray 3 "isosurf: 3 3 0.3 0 -1 0 0 10 30 1 0" "remesh: 0.5 0 0 2 30" "other_params: 1 0 0 0 10"
*ossmooth_12 1 1 0 3 "c:/test/os1.fem" "c:/test/os1.sh" "" 1 0 1 2
      To execute ply smoothing on
C:/test/os2.fem, eliminate small element
        patches and holes with less than 20 elements, smoothing plies with 20 iterations, split
        disconnected patches into new plies, export smoothed result plies into
C:/test/os2_smooth.fem:
*createstringarray 1 "ply: C:/test/os2_smooth.fem 20 1 20 1"
*ossmooth_12 0 2 0 1 "C:/test/os2.fem" "" "" 0 0 1 1
      Incorrect usage results in a
Tcl error. To detect
        errors, you can use the
catch
        command:
   # Handle error
