*hwct_openlibrary
Opens a library
*hwct_openlibrary entity_type params
HyperMesh Tcl Modify Command
Opens a library. Once the library is connected all entities are updated with information present in the library.
entity_type
The type of connected library. Currently only supported for subsystems.
params
A quoted, comma separated string, containing additional optional name=value parameters. Valid parameters are:
libraryname=<value>
The name of the library to open.
overwriteattributes=<value>
0 - Do not overwrite the attributes when merging
1 - Overwrite the attributes when merging
password=<value>
The library password.
user=<value>
The library user name.
usersettingsfilepath=<value>
The path of the user settings file for connecting to the library.
workspacename=<value>
The local in-work repository name.
Examples
Open SubsystemLibrary1:
*hwct_openlibrary subsystems "usersettingsfilepath=c:/Users/me/.Altair/AltairSubsystemLibrarySettings2020.xml, libraryname=SubsystemLibrary1, workspacename=SubsystemWorkspace1, user=me"
   # Handle error
Version History
2020
