*jointelement_sixnoded
Creates a six-noded joint element.
*jointelement_sixnoded type n1 n2 n3 n4 n5 n6 orientation system1 system2 property
HyperMesh Tcl Modify Command
type
The type of the element (6 or 7 ONLY)
n1, n2, n3, n4, n5, n6
The six nodes of the element.
orientation
Orientation option for the element. Use:
  • 0 - None
  • 1 - Systems
system1
The orientation systems’ IDs for the element.
property
The property to which the element points.
To create a six-noded joint element:
*jointelement_sixnoded(7,464,457,456,455,463,462,1,1596,1592,"")
None.
