*applyresultsasloads
Create loads at an entity's nodes based on a models result information.
*applyresultsasloads entities mark multiplier datatype loadtype loadcomp
HyperMesh Tcl Modify Command
entities
The entity type.
mark
The mark which contains the entities to be added to the set.
multiplier
The multiplier to apply to the result.
datatype
The data type.
loadtype
The type of load to create.
For vector datatypes:
forces
moments
velocities
accels
For scalar datatypes:
temp
flux
loadcomp
The load component. The value is only used for vector data types; it should be set to 0 for scalar data types. It may be specified as one of the following:
total
comp1
comp2
comp3
0
