*mergefile
Merges a HyperMesh binary file into the current model.
*mergefile filename geom_merge fe_merge
HyperMesh Tcl Modify Command
Merges a HyperMesh binary file into the current model. Any entity names or IDs in the incoming file are renamed/renumbered with the least disruption possible.
- filename
 - The full path and filename of the database file.
 - geom_merge
 - A flag indicating whether to import and merge geometry from the incoming model. If both geom_merge and fe_merge are 0, this behaves like *readfile.
 - fe_merge
 - A flag indicating whether to import and merge FE from the incoming model. If both geom_merge and fe_merge are 0, this behaves like *readfile.
To merge the file named C:/mymodel.hm into the current session:
*mergefile C:/mymodel.hm 1 1
   # Handle error
