*hf_ScaleBinderSurf
Scale the binder dimension. The binder is automatically identified.
*hf_ScaleBinderSurf base_point_id scale_factor_x scale_factor_y scale_factor_z
HyperMesh Tcl Modify Command
This command increases and decreases the binder dimension. The binder is scaled relative to an origin node. The scaling can be uniform or not. If uniform scaling is requested, the scale factor in all directions should be set equal. Otherwise, it is possible to give different value to these factors in other to obtain a non-uniform scaling.
- base_point_id
 - The node ID to use as the base point for the scaling.
 - scale_factor_x
 - Scale factor in x.
 - scale_factor_y
 - Scale factor in y.
 - scale_factor_z
 - Scale factor in z.
Examples
*hf_ScaleBinderSurf 1434 5 5 5*hf_ScaleBinderSurf 1434 0.2 0.1 0.05Errors
   # Handle error
}Version History
10.0
