*dummyplacerootbodytopoint
Moves a dummy from a source point to a target point.
*dummyplacerootbodytopoint name sx sy sz tx ty tz tolerance
HyperMesh Tcl Modify Command
The mechanism must have the enabled flag set to true for this to be possible.
name
The name of the root body of the dummy.
sx
The x-coordinate of the source point. This is usually the x-coordinate of the H-Point of the dummy.
sy
The y-coordinate of the source point. This is usually the y-coordinate of the H-Point of the dummy.
sz
The z-coordinate of the source point. This is usually the z-coordinate of the H-Point of the dummy.
tx
The x-coordinate of the target point.
ty
The y-coordinate of the target point.
tz
The z-coordinate of the target point.
tolerance
The tolerance allowed during the placement.
To move a dummy with root body named "Pelvis Angle Gauge" from (0,0,0) to (150,100,200):
*dummyplacerootbodytopoint "Pelvis Angle Gauge" 0 0 0 150 100 200 0.001
   # Handle error
Version History
14.0.120
