*orderchangetosecond
Converts first order elements to second order.
*orderchangetosecond mark doproject tacitmode
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark that contains the elements to be converted.
 - doproject
- 0 - Places the new midside nodes at the exact midpoint
 - 1 - Projects the new midside nodes to the surfaces
 - tacitmode
- 0 - Does not project the new midside nodes to the inferred surface
 - 1 - Uses the inferred surface where there is no geometry
To change first order elements to second order:
*createmark(elements,1) 25 26 35 36
*orderchangetosecond(1,1,1)
      *createmark() is required.
None.
