*tabledeleterow
Deletes a row of data from a table.
*tabledeleterow name row_index
HyperMesh Tcl Modify Command
name
The name of the table to update.
row_index
The index of the row to delete. Tables are indexed starting from 1 (1 to n rows). If specified as 0, the last row in the table is deleted.
Examples
To delete the last row from table1, which has 11 rows:
*tabledeleterow table1 0
or
*tabledeleterow table1 11
To delete row 3 from table1:
*tabledeleterow table1 3
   # Handle error
Version History
11.0
