*hm_trim_elements_with_predefined_box
Trims shell elements using a predefined box.
*hm_trim_elements_with_predefined_box mark_id cut_type limit spc_collector_name box_collector_name remesh_params
HyperMesh Tcl Modify Command
Trims shell elements using a predefined box. Shell elements inside the box are kept with the elements along any cuts re-meshed. Solid elements with all nodes inside the box are kept, while all others are deleted.
- mark_id
 - The ID of the mark containing the elements to cut. Valid values are 1 and 2.
 - cut_type
 - A predefined cut name. Valid values are left, right, front, rear, frontleft, frontright, rearleft or rearright.
 - limit
 - The x value of the box for cut types front, rear, frontleft, frontright, rearleft or rearright.
 - spc_collector_name
 - The name of the collector in which the SPCs will be created for constraining cut elements.
 - box_collector_name
 - The name of the collector in which a hexa might be created to show the cutbox.
 - remesh_params
 - The parameters of re-meshing along the cut, defined as "keyword value" format.
To trim displayed elements using a left box, with limit of 50:
*createmark elements 1 "displayed"
*hm_trim_elements_with_predefined_box 1 "left" 50.0 "abc" "efg" "min_elem_size_rate 0.6 comp_remainder_elem_rate 0.01 angle 30.0"
   # Handle error
}Version History
12.0.110
