*groupsetconfigtype
Sets the configuration and type for a group entity.
*groupsetconfigtype mark_id destination_config destination_type
HyperMesh Tcl Modify Command
Updates the configuration and the type of the selected group entities during basic entity conversion.
mark_id
The ID of the mark containing the group entities to updated. Valid values are 1 and 2.
destination_config
The group configuration that is equivalent in the destination profile.
destination_type
The group type that is equivalent in the destination profile.
Examples
To update the CONTACT_PAIR groups to configuration 2 and type 1:
*createmark groups 1 “by card image name” CONTACT_PAIR
*groupsetconfigtype 1 2 1
   # Handle error
Version History
2022
