*unmaskentitymark
Unmasks the entities on the specified mark.
*unmaskentitymark entity_type mark_id flag
HyperMesh Tcl Modify Command
This command unmasks the entities of entity_type that are on mark_id. Valid mark_ids are 1 and 2. Only entities in displayed collectors may be unmasked.
To unmask connectors and the realized FE, a flag of 1 must be passed. To unmask only connectors (excluding realized FE) and all other entity types, a flag of zero must be passed.
- connectors
 - points
 - lines
 - surfaces
 - solids
 - elements (both in components and groups)
 - ellipsoids
 - mbjoints
 - mbplanes
 - equations
 - loads
 - systems
 - vectors
 - tags
 - handles
 - domains
 - symmetries
 - morphconstraints
 - comps (connectors, points, lines, surfaces, solids, elements)
 - groups (main/secondary elements)
 - loadcols (equations, loads)
 - multibodies (ellipsoids, mbjoints, mbplanes)
 - systcols (systems)
 - vectorcols (vectors)
Examples
To unmask all of the displayed connectors and the realized FE:
*createmark connectors 1 displayed
*unmaskentitymark connectors 1 1
      To unmask all elements in components but not elements in groups:
*createmark comps 1 all
*createmark elems 1 "by comps on mark" 1
*unmaskentitymark elems 1 0
      To unmask all entities in all components:
*unmaskentitymark comps 1 0
This command does not return any errors that can be handled.
Version History
9.0
