*features_add
Creates elements or lines between a list of nodes.
*features_add node_list lines smooth
HyperMesh Tcl Modify Command
- node_list
 - The number of the desired list of nodes.
- 0
 - 1
 - lines
- 0 - Create plot elements connecting the nodes in the list. These elements are created in the component named ^open features. Next, elements in the ^open features component that create closed chains (loops) of elements are moved to a component named ^feature.
 - 1 - Creates a line in the "^feature" component.
 - smooth
- 0 - Do not smooth the lines.
 - 1 - Smooth the line created through the nodes of the feature.
*features_add(0,1,1)
