*linessmoothtoangle
Smooths a line based on a give angle.
*linessmoothtoangle mark cosangle
HyperMesh Tcl Modify Command
- mark
 - The ID of the mark containing the lines to smooth.
 - cosangle
 - The cosine of the angle used to determine if two joints on a line should be combined (smoothed). If the angle between two joints on a line is greater than the angle the two joints are combined and smoothed.
To smooth all joints on line 1 that have an angle greater than 90 degrees:
*createmark(lines,1) 1
*linessmoothtoangle(1,0)
None.
