*createdynamicdataname
Creates a dynamic dataname on an entity.
*createdynamicdataname entity_type mark_id dataname=<value> displayname=<displayname > basictype=<value> ?defaultvalue=<value>? ?visible=<value>? ?editable=<value>?
HyperMesh Tcl Modify Command
Creates a dynamic data name on an entity. The entity must support dynamic data names.
entity_type
The type of the entity to create the data name on.
mark_id
The ID of the mark containing the entities. Valid values are 1 and 2.Valid values are 1 and 2.
dataname=<value>
The name of the dataname.
basictype=<value>
The basic type of the dataname. Valid values are unsigned int, float, double, and string.
displayname=<value>>
The display name of the dataname.
The default value of the dataname.
visible=<value>
Defines the visibility of the dynamic data name.
0 – Off
1 – On
editable=<value>
Defines whether the dynamic data name is editable.
0 – Disabled
1 – Enabled
Examples
To create dynamic data name for structuralproperty2 and structuralproperty3 entities with the name and display name “Buckling_constant”, the basic type double and the default value 0.272:
*createmark structuralproperties 1 "structuralproperty2" "structuralproperty3"
*createdynamicdataname structuralproperties 1 dataname=Buckling_constant
displayname=Buckling_constant basictype=11 defaultvalue=0.272
   # Handle error
Version History
2022
