*multi_trim_by_offset_edges
Trims the selected surfaces by offsetting selected edges by a given distance. Offset can be applied multiple times.
*multi_trim_by_offset_edges input_surf_mark=<mark_id> input_line_mark=<mark_id> offset_distance=<value> offset_count=<value>
HyperMesh Tcl Modify Command
Offsets the selected edges and trims the input surfaces using the offset edges. You have the option to offset the original edges with the same distance multiple times.
The ID of the mark containing the input surfaces. Valid values are 1 and 2.
The ID of the mark containing the input edges to be used for offsetting and trimming the input surfaces. Valid values are 1 and 2.
The offset distance.
The number of offsets to be performed. The value should be greater than 0.
To trim surface 2 by offsetting edges 10, 12, 14, 15 by distance 5.0, 4 times.
*createmark surfaces 1 2
*createmark lines 2 10 12 14 15
*multi_trim_by_offset_edges input_surf_mark=1 input_line_mark=2 offset_distance=5.0 offset_count=4
   # Handle error
Version History
2021.1
