*hmmeshsurfacetorus
Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with *surfacemode 3 and one of the *surfacetorus... commands.
*hmmeshsurfacetorus quads
HyperMesh Tcl Modify Command
quads
If nonzero, specifies that the created elements should be quads.
This example identifies a region that corresponds to the upper half of a torus, and without making a surface, creates 400 elements with a density of 40 around the major circumference of the torus and 10 across the upper half.
*surfacemode 3
*surfacetorus 17 19 18 20.0 115.0 0.0 360.0 0.0 180.0
*set_meshedgeparams 0 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 1 40.0 0 0 0 0 0 0 0
*set_meshedgeparams 2 10.0 0 0 0 0 0 0 0
*set_meshedgeparams 3 40.0 0 0 0 0 0 0 0
*hmmeshsurfacetorus 1
*storemeshtodatabase 0
*ameshclearsurface
None.
