*removeview
Deletes a saved view from the database.
*removeview name
HyperMesh Tcl Modify Command
name
The name of the view to delete. The view names 1-5 are reserved and cannot be deleted.
To delete the view with the name "my_view":
*removeview "my_view"
   # Handle error
Version History
9.0
