*CE_ReverseSigPoints
Reverses the direction of a line connector.
*CE_ReverseSigPoints connector_id
HyperMesh Tcl Modify Command
connector_id
The ID of the connector.
Examples
To reverse the direction of line connector ID 1:
*CE_ReverseSigPoints 1
   # Handle error
Version History
2022
