*nodelistbypath2
Creates a node path from the starting node to the ending node.
*nodelistbypath2 node_id1 node_id2 list_id flag
HyperMesh Tcl Modify Command
- node_id1
 - The ID of the first node.
 - node_id2
 - The ID of the second node.
 - list_id
 - The ID of the node list to populate. Valid values are 1 and 2.
 - flag
 - 0 - If both node_id1 and node_id2 lie on free edges, the path will follow free edges where possible. Otherwise, the shortest path is returned. This is the same as running *nodelistbypath.
To determine the path between nodes 100 and 110 using the shortest path:
*nodelistbypath2 100 110 1 1
   # Handle error
}Version History
10-SA1-130
