*ME_ModuleOccurrenceReparent
Move a module part or part assembly underneath another part assembly in the model hierarchy.
*ME_ModuleOccurrenceReparent child_id parent_id ?options?
HyperMesh Tcl Modify Command
Move a module part or part assembly underneath another part assembly in the model hierarchy. This is only allowed in cases where it does not break sub-assembly instancing.
child_id
The ID of the module to move. The module must be an occurrence.
parent_id
The ID of the module part (if empty and convertible to a part assembly) or module part assembly to become the parent.
options (optional)
List of input options, passed as a comma separated string enclosed in quotes. Valid options are:
matrix_mode=<mode>
0 - Retain the relative position of the child module (default). This may cause the part to translate if there are matrices stored at different levels in the hierarchy.
1 - Retain the absolute position of the child module.
Reparent module 100 under part assembly 8 in the hierarchy, keeping the absolute matrix:
*ME_ModuleOccurrenceReparent 100 8 "matrix_mode=1"
   # Handle error
Version History
14.0
