*interfaceadd
Creates interface elements.
*interfaceadd name main type mark reverse
HyperMesh Tcl Modify Command
- name
 - The name of the group into which the interface elements should be placed.
 - main
 - Use 1 for main; 0 for secondary.
 - type
 - The entity type of the secondary entities (none, elements, nodes).
 - mark
 - The ID of the mark containing the nodes or elements which should have main or secondary elements placed on them.
 - reverse
 - A logical which determines if the secondary elements should be reversed when created.
None.
