*maskentitymark
Masks the entities on the specified mark.
*maskentitymark entity_type mark_id flag
HyperMesh Tcl Modify Command
This command masks the entities of entity_type that are on mark_id. Valid mark_ids are 1 and 2. Only entities in displayed collectors may be masked.
To mask connectors and the realized FE, a flag of 1 must be passed. To mask only connectors (excluding realized FE) and all other entity types, a flag of zero must be passed.
Currently supported entity_types for this command are:
connectors
points
lines
surfaces
solids
elements (both in components and groups)
ellipsoids
mbjoints
mbplanes
equations
loads
systems
vectors
tags
handles
domains
symmetries
morphconstraints
comps (connectors, points, lines, surfaces, solids, elements)
groups (main/secondary elements)
loadcols (equations, loads)
multibodies (ellipsoids, mbjoints, mbplanes)
systcols (systems)
vectorcols (vectors)
To mask all of the displayed connectors and the realized FE:
*createmark connectors 1 displayed
*maskentitymark connectors 1 1
To mask all elements in components but not elements in groups:
*createmark comps 1 all
*createmark elems 1 "by comps on mark" 1
*maskentitymark elems 1 0
To mask all entities in all components:
*maskentitymark comps 1 0
This command does not return any errors that can be handled.
