*solidcreatespinsurfwithoffsetangle
Create solids by rotating a set of selected surfaces around a given axis.
*solidcreatespinsurfwithoffsetangle surf_mark rotation_plane start_angle end_angle options comp_mode
HyperMesh Tcl Modify Command
This command creates one or more solids by rotating a given set of surfaces around a given axis.
- surfs_mark_id
 - The mark containing the surfaces that you wish to rotate to create solids.
 - rotation_plane
 - The plane whose normal is used as the rotation axis and its base point used as the rotation center. This plane is created using the *createplane command.
 - start_angle
 - Degrees value of initial rotation angle: selected surfaces are rotated by this value before solid "sweeping" begins.
 - end_angle
 - Degrees value of final rotation angle: solid "sweeping" stops at this value.
 - options
 - Flags that indicate different modes for solid creation. Bit values are used and the
            value is calculated as (Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3).
- Bit0
 - 0 - Only free edges of surfaces are rotated.
 - Bit1
 - 0 - Create solid entities.
 - Bit2
 - 0 - Selected surfaces become part of solid boundary.
 - Bit3
 - 0 - Solid surfaces are ignored as input.
 - comp_mode
 - Determines how new solids are organized into components. Valid values are:
To create a solid by rotating surface 1 around an axis defined by the direction vector (1 2 3) with a rotation center at point (4 5 6) and using a full 360 degrees angle, creating a solid in the same component as surface 1, and keeping the surface 1 intact:
*createmark surfs 1 1
*createplane 1 1 2 3 4 5 6
*solidcreatespinsurfwithoffsetangle 1 1 0 360 4 2
   # Handle error
}Version History
10.0
2019 - Added new options Bit3.
