*tableupdatelabels
Updates the column labels of a table.
*tableupdatelabels name string_array number_of_strings
HyperMesh Tcl Modify Command
name
The name of the table to update.
string_array
The ID of the string array that contains the column labels to update. The string array is created using the *createstringarray command. This should always be set to 1.
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray. This must equal the number of columns in the table.
To update the labels for table1 with 3 columns:
*createstringarray 3 "Name" "ID" "Thickness"
*tableupdatelabels table1 1 3
   # Handle error
Version History
11.0
