*setlegendbackgroundcolor
Sets the HyperMesh legend background color.
*setlegendbackgroundcolor red green blue alpha
HyperMesh Tcl Modify Command
This command sets the HyperMesh legend background color. This applies to all HyperMesh legends.
red
The red color value, from 0.0 to 1.0.
green
The green color value, from 0.0 to 1.0.
blue
The blue color value, from 0.0 to 1.0.
alpha
The alpha transparency value, from 0.0 to 1.0.
Examples
To set the legend background color to red with no transparency:
*setlegendbackgroundcolor 1.0 0.0 0.0 1.0
Set legend background color to gray with some transparency:
*setlegendbackgroundcolor 0.5 0.5 0.5 0.5
   # Handle error
Version History
12.0.110
