*element_smooth_nodes
Smooth a selection of elements with optional anchor nodes.
*element_smooth_nodes mark_id node_mark_id ?option1=<value1>? ?option2=<value2>? ... ?optionN=<valueN>?
HyperMesh Tcl Modify Command
<option>=<value> options can be provided in any order.
- mark_id
 - The ID of the mark containing the elements to smooth. Valid values are 1 and 2.
 - node_mark_id
 - The ID of the mark containing any anchor nodes. Valid values are 1 and 2.
 - Iterations=<value>
 - The maximum number of smoothing iterations to perform (default 1).
 - Method=<value>
 - The smoothing method.
- TimeLimit=<value>
 - The time limit in minutes for QI and AutoDecideWithQI (default is off).
Smooth elements 100-200 with anchor nodes 150 and 151 using QI method:
*createmark elements 1 100-200
*createmark nodes 1 150 151
*element_smooth_nodes 1 1 Method=QI
   # Handle error
}Version History
2019.1
2020 - Added new Method value AutoDecideWithQI_Params_locked.
