*attributeupdateintarraymark
Updates an attribute of type int array on a set of entities.
*attributeupdateintarraymark entity type mark identifier solver status behavior data length
HyperMesh Tcl Modify Command
- entity type
 - The entity type that owns the attribute.
 - mark
 - The number of the mark.
 - identifier
 - The identifier of the attribute.
 - solver
 - The solver number of the attribute.
 - status
 - The status of the attribute.
 - behavior
 - The behavior of the attribute.
 - data
 - The int array.
 - length
 - The int array length.
Examples
Update an attribute of type int array to [1, 2, 3, and 4] on the materials with ID's 7 and 8.
*createmark(materials,1) 7 8
*createintarray(4) 1 2 3 4
*attributeupdateintarraymark(materials,1,615,2,2,0,1,4)
