*midsurface_clear_plate_info
Deletes the plate and thickness information from selected surfaces.
*midsurface_clear_plate_info mark_id reserved1 reserved2
HyperMesh Tcl Modify Command
Deletes the plate and thickness information from selected surfaces, which was created via previous midsurface runs, or via plate edit commands.
mark_id
The ID of the mark containing the surfaces to clear. Valid values are 1 and 2.
reserved1
Reserved for future use. Must be set to 0.
reserved2
Examples
To delete the plate and thickness information from surfaces with ID 5-7:
*createmark surfs 1 5-7
* midsurface_clear_plate_info 1 0 0
   # Handle error
Version History
2019
