*surfacesplinefrompoints
Creates a spline surface using selected nodes or points as boundary conditions.
*surfacesplinefrompoints entity_type mark_id options
HyperMesh Tcl Modify Command
- entity_type
 - The type of entity to use as input. Valid values are nodes and points.
 - mark_id
 - The ID of the mark containing the input entities. Valid values are 1 and 2.
 - options
 - Specifies options for creating the surface. Bit values are used and the value is
            calculated as (Bit0 + 2*Bit1 + 4*Bit2)
- Bit0
 -  Surface trim mode
- 0 - Trim by parametric rectangle.
 - 1 - Trim by points boundary.
 - Bit2
 - Mesh stitching. Used to control the connectivity of the mesh created on the new
                  spline surface in simultaneous meshing modes.
- 0 - New mesh is not connected.
 - 1 - If *surfacemode is set to 1, existing mesh nodes are used if new spline edges are stitched to those lines.
To build a spline from the displayed points and do not connect mesh:
*surfacemode 1
*createmark points 1 "displayed"
*surfacesplinefrompoints points 1 0
*surfacemode 1
*surfacesplinefrompoints points 1 4
   # Handle error
