*vectorcreate_xproduct
Creates a vector entity by using the cross product of two other vectors.
*vectorcreate_xproduct basenode vector A vector B magnitude
HyperMesh Tcl Modify Command
basenode
The ID of the node where the base of the result is located after it is created.
vector A
The ID of the first vector entity in the cross product.
vector B
The ID of the second vector entity in the cross product.
magnitude
Magnitude of resulting vector.
None.
